Help!!!! Going crazy with this car
My car with not turnover. I tries turning over, and if it does, it is only for about 5 secs and then shuts off. What is the problem. I just put in a new starter. Could it be the fuel pump? How do I test it?
Is it really hard to change a head gasket with three people? How long should it take?
RE: Help!!!! Going crazy with this car
well with three people it shouldnt take to long if you know what you are doing. itll most likely eat up a day, and your idle could be off to much to where it wont turn, try adjusting your BISS screw on top of the throttle body.
What am I checking for on the air filter? Brand new K&N filter 3 weekends ago. Two weekends ago we had a down por of rain, could that of damaged the air filter? Changed the fuel filter and it still does it. What about overfueling itself (flooding itself). It turns over for about 30 secs and shuts off. Even when it turns over and i give it some gas it still shuts off. If u are standing in front of the car, I did notice that #2 injector from the left is leaking. Why? All the way hooked up. Please respond fast. Thanks
Wiloz32
01-29-2013 01:46 PM
posceola
03-13-2011 07:29 PM
Evo_8
10-28-2005 09:41 AM
