i need help!!!! cars runnin ****ty advice needed
Old Jan 18, 2007 | 11:53 PM
awd92tsi's Avatar
Default i need help!!!! cars runnin ****ty advice needed
my talon is runnin ****ty!!! car wont stay runnin on its own... do know if theres a leak sumwhere or if a sensor is bad.... im drawin blaks.. u have to keep hittin the gas to keep it runnin.... it will then clean it self out... run at idle and then when u take it up to high rpm it will on go to like 5500 and when it comes back down it trys to stall out again.. if theres is anybody out there who can help me solve this problem let me know it would be much appreciated!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old Jan 19, 2007 | 12:41 AM
Default RE: i need help!!!! cars runnin ****ty advice needed
Check your plugs and wires.
Old Jan 19, 2007 | 11:20 AM
it sounds like a vaccuum leak to me. Or maybe even check the battery terminals they might be corroded. I had that problem and felt pretty stupid when thats all it was.
Old Jan 20, 2007 | 08:31 AM
silvercoupe97's Avatar
Wow, there's too much partial info in your post to really help.
It could be plugs and wires, it could be a boost leak (this is a DSM issue almost 90% of the time if not more), it could be a bad ISC, etc. You can replace all of that if you like, but I'd rather ask you for your mods.
Do you have your BOV recirculated or is it vented, if it is vented, put the recirc tube back on and let us know how it worked out for you. This just sounds like a case of a vented bov.
Old Feb 21, 2007 | 01:01 PM
raff1ut's Avatar
ORIGINAL: awd92tsi
cars runnin ****ty advice needed . Hmm ... If I were to read this a certain way it would appear that you are seeking ****ty advice lol.
Old Mar 20, 2007 | 12:58 AM
IcEcuBe's Avatar
My car was acting similar, sometimes it would idle fine and other times it would idle real low an die. Anyway it ending up being a O2 sensor, after so long the sensor gets covered carbon and wont read correctly then the ecm cant tell your air/fuel ratio and defaults to a preset air/fuel mixture.
Old May 29, 2007 | 12:51 PM
BlackMurcielago's Avatar
With o2 sensor is ti and where is it because mine is doing that exact thing and its pissing me off
Sheijin
Feb 27, 2008 09:58 PM
slvr_eclipse
Aug 13, 2006 12:14 AM
a2rht930
Apr 10, 2006 01:13 AM
