throttle body q's
throttle body q's
Im lookin at getting a bigger TB for my spyder, my question is are there other parts i will need, such as a 1g elbow for a 1g TB, will upgrading the fuel system in this case help? thanks..........
RE: throttle body q's
I would imagine that you'd have to get some additional parts for that, but not possotive n witch ones. I would consider upgrading the fuel system as well because the two work togeter. There needs to be a harmonious ratio of air to fuel mixture depending on the set up of your engine. If you upgrade air intake but not the fuel system, you may be running lean and actully see less performance. You can stop by or call an engine performance shop and tell them what your buying and see what adjustments they recomend for the fuel system. You may just end up needed to retune and that's all.
You don't have to do a fuel upgrade with a throttle body cause it's not a huge differance. It's simply less restrictive such as putting in a cold air intake or a cone filter. The computer will compensate for a certain amount of change in the air/fuel ratio. If you were intalling a new intake manifold or something like that you'd def want to upgrade the fuel system at least with a better pump. One the other hand if you've got plans and the money you may as well do it now and get it done. If you wanna go all out you can do rails, injectors, pump, and an adjustable fuel pressure regulator and you should be all set.
yea, i knew i wouldnt need it simply for the tb, i just figured while i was in there i should do it to get it out of the way......... but all is on hold till i get some cashflow again anyway...........[]
