Ignition problem!!
Old Nov 14, 2006 | 12:38 AM
juve0882's Avatar
Default Ignition problem!!
I have a 95 eclipse non turbo 2.0L, I have replaced the crankshaft position sensor, coil pack, changed the spark plug wires. I am going to change the camshaft position sensor tomorrow, but if that doesn't work, what would be the problem? The car turns over and everything but does not start. I took a spark plug wire off and checked for sparks but didn't get anything....So i need help on what other sensors there are that are tied to the Ignition System..(Crankshaft, Camshaft, and thats all the sensors that i know) So if anyone can relate or help with this problem it will be very helpful.. Thanks
Old Nov 14, 2006 | 10:32 AM
Default RE: Ignition problem!!
sounds like a cam position sensor to me. I dont know what else it could be if its turning over but getting no spark
Old Nov 14, 2006 | 02:29 PM
juve0882's Avatar
Hey could it maybe be the fuel pump relay?
Old Nov 14, 2006 | 02:31 PM
in that case though i would think you would get spark. IDK though. When your turning it over see if you can hear the fuel pump
Old Nov 14, 2006 | 08:42 PM
juve0882's Avatar
ok thanks im going to replace the camshaft and the fuel pump relay and see if that works.. I'll let you guys know
Old Nov 18, 2006 | 01:30 AM
juve0882's Avatar
Ok so i replaced the Cam shaft position sensor and still got nothing.. The fuel pump relay is good, so no need to replace that. I tested the fuel pump and its running. But the weird thing is that i am getting no gas. I took off the nozzle on the gas line thing and pushed the button and recieved no gas.. I think it might be the PCM..I have done everything you can possibly do. I used the Hanes mitsubishi eclipse guide book to do all the test involved with the ignition and electrical system.. Do you have any other idea what it could be? Still not getting any fire what so ever. I did spray starter fluid in it and it wanted to start at one point and then it stop.
Old Dec 14, 2006 | 05:05 PM
slightflyer's Avatar
I have the same problem, but the model is eclipse 92 GS, no gasoline, not hear the fuel pump and I don't know where the relay is; and no spark at all. Do you have some idea about the problem ?
Old Dec 17, 2006 | 03:59 PM
juve0882's Avatar
hey whats up slight flyer..i have done every test that hanes has in the book that ties with the ignition and nothing works, so my guess is that its the ECU so i guess i need a ecu for it.. but i would invest in the hanes manuel for your car..its great and very helpful..good luck! if you find anything else let me know
Old Apr 29, 2007 | 08:02 PM
johnthornhill's Avatar
Hello everyone. I know this is an older posting but I really need to knoe if the problem was ever resolved and if so HOW? I have a 97 GS that is doing the same thing and I'm running out of ideas. no I have ran out of them. PLEASE HELP!!!!!!!!!
Old Apr 29, 2007 | 08:53 PM
silvercoupe97's Avatar
It can also be the ASD relay and ECU.
Here's some more info on the ASD that I just posted up.
https://mitsubishiforum.com/m_137146.../tm.htm#137146
