Outlander 2007 DiD 2.0
Old 04-08-2017, 02:46 PM
Ssm2200's Avatar
Default Outlander 2007 DiD 2.0
I'm doing my own service on this vehicle and want to change the fuel filter. I'm a novice tinkerer and thought i would need to reduce pressure in the fuel line before removing to change the filter. I removed the fuel pump fuse and ran the engine thinking it would cut out when pressure was reduced, it didn't! I've then looked for a bleed valve and can't find one.
Can anyone please advise how to do this if indeed it needs done before disconnecting the fuel pipes to change the filter?
Many thanks
Simon
monxla
04-16-2017 04:40 PM
Ssm2200
04-08-2017 12:15 PM
KayKay75
06-15-2016 05:33 AM
jdubnz
03-26-2015 10:16 AM
azchipka
10-07-2008 08:43 AM
Quick Reply: Outlander 2007 DiD 2.0
