tuning
I was just wondering if you guys have any advice on tuning, I'm going to be putting in a safcII next weekend. I have a 2nd gen with turboback exhaust, mbc, bov, intake, and a lotta other stuff, just not a turbo upgrade yet. I was planning to lean it out a little because its really rich right now.
RE: tuning
Ok first off how do you know it running lean? You don't...you need a wideband O2 sensor, or a slow EGT. Then you find out the ideal AFR and tune your car to it. I doubt the car is running rich if anything its running to lean right now....depending on your boost setting. Your best bet is to get a wideband first before the AFC....the AFC is useless with out it, don't even try to tune with out it you will probably blow your motor, especially if you think you want to lean it out.
RE: tuning
ORIGINAL: NESpeed Ok first off how do you know it running lean? You don't...you need a wideband O2 sensor, or a slow EGT. Then you find out the ideal AFR and tune your car to it. I doubt the car is running rich if anything its running to lean right now....depending on your boost setting. Your best bet is to get a wideband first before the AFC....the AFC is useless with out it, don't even try to tune with out it you will probably blow your motor, especially if you think you want to lean it out. |
RE: tuning
http://www.extremepsi.com/store/cust...cat=747&page=1
should i get this since im going to put an safc in my car to? |
RE: tuning
yes
RE: tuning
thanks, after i get that and the afc installed can you guys help me out with it.
im pretty sure you will but i just want to ask. |
RE: tuning
that is what you want bat that is a high price for a wideband O2. Try either ebay (not totally a good choice but an option) or go here, it is much cheaper. You don't need the PLX one if all your using it for is the SAFC
http://tearstone.com/shop/index.php?...d=105&Itemid=2 |
RE: tuning
yeah i dont totally trust ebay. and ill go with the wideband from tearstone.
RE: tuning
ORIGINAL: 93eclipsegsx yeah i dont totally trust ebay. and ill go with the wideband from tearstone. http://i33.photobucket.com/albums/d9...exhaust002.jpg |
RE: tuning
Do you have any fuel mods? If not you should really consider purchasing a fuel pump and injectors before or with the AFC....
