What goes between these connectors? 96' Eclipse GST
I've got an 1996 Eclipse GST and I've been working on trying to get it running. I've determined tonight that the fuel pump is bad so I'm replacing that. I've got a question though, I wasn't getting any power to my fuel pump so I traced a break in the wire to the engine compartment. There is where I found some open connections. I just "ghetto" wired a connection wire but there is still one open connector. Can anyone tells me what goes here? I think it may be the automatic shutoff for the fuel pump? Pictures below:
Here are the connectors:
Here are where they are in the engine compartment, right behind the intake:
After doing some searching through replacement parts online, I think I've found the part myself.
http://www.partsamerica.com/ProductD...artNumber=FSV7
Can someone confirm this for me?
1996, 96, 97, compartment, connector, connectors, description, eclipse, electrical, engine, fuel, gst, parts, performance, pump, timing
