selling my 95 gst
95 Elcipse gst I recently completed this project car. This eclipse has a new balanced motor, tons of new parts...OEM and aftermarket. This motor is fresh from top end to bottom! I only have about 1200 miles on the new block, It has about 5k worth of body work and paint...just completed the body work last month....the body is prestine. I do not like body kits(the flashy ricer look) so i kept the stock appearance of the car and made it look stealthy, with the black paint, smoked lights, tinted windows, and black projecter head lights. Its a very fun and fast car.This car is garaged every night, it truly is a nice looking car that will run strong for a long time! To make tons of power with this car just upgrade the turbine and fuel system, the motor can handle tons boost... Balanced & rebuilt bottom end (balanced crank, rods, pistons, dampner, flywheel, pressure plate), surfaced block, jet washed and mag block, measured and polished crankshaft, ball & finish hone cylinders, bored 40 over, resized rods, balance shaft eliminator kit, align and hone mains, OE oil pump and front case.$1750.52 Rebuilt top end (swirl polished ferra racing valves, bronze valve guides ,dual spring valve springs, titanium retainers, spring seat locators, valve stem seals, 3rd generation lash adjusters, cosmetic performance head gasket )$ 750.00 Exedy clutch kit & resurfaced stock flywheel $305.00 New crank sensor $45.00 New knock sensor $49.00 New cam position sensor $39.00 New coil pack $55.00 New alternator $75.00 New water pump $35.00 All new belts, timming, alt, ac, pwr steering+ install (235.50) All new gaskets with the fresh motor& parts $75.75 Powder coated metalic blue valve cover $110.00 Light weight crank pulley $25 PWR double thick lower turbo tubing $100.32 Stock & aftermarket BOV Stainless steel ported o2 housing(from turbo to down pipe) 74.88 3" catless down pipe $135 2.5" exhaust piping to $250 Magnaflow muffler, race style, 2x3.5 in" tips $152.00 Accel plug wires 8mm $24.99 Denzo iruidum spark plugs $46.99 HKS turbo timmer $129.99 Strut brace $51.00 New koyo high flow radiator $154.00 New performace spal cooling fan(flows 1375cfm) $110.00 New o2 sensor $45.00 Boost guage $38.00 Custom heat shield for turbo $75.00 Smoked tail lights $150.00 Tinted windows $300 Smoked reverse lights $45.00 Projector head lights 159.95 Silva star bulbs set $120.00 New front bumper reflectors( old faded) $25.00 17" ADR design rims(8 spoke) $900 New kumho 711 tired( not even 1000 miles on the tires) 277.88 Rockford fosegate 6.5 power front speakers, $155 Kenwood KDC-3028 deck $200.00 Sun/moon roof Power door locks Power winodows Power seats Heat and ac work great $7269.77 just in upgrades! IM ASKING $8700 obo here are some pics of the car... before all the body work and paint http://i32.photobucket.com/albums/d24/omgitsteven/HPIM1002.jpg http://i32.photobucket.com/albums/d24/omgitsteven/HPIM1003.jpg http://i32.photobucket.com/albums/d24/omgitsteven/HPIM1012-1.jpg http://i32.photobucket.com/albums/d24/omgitsteven/eclipse12.jpg and after all the body work and paint http://i32.photobucket.com/albums/d24/omgitsteven/eclipse1.jpg http://i32.photobucket.com/albums/d24/omgitsteven/eclipse2.jpg http://i32.photobucket.com/albums/d24/omgitsteven/eclipse10.jpg http://i32.photobucket.com/albums/d24/omgitsteven/eclipse9.jpg http://i32.photobucket.com/albums/d24/omgitsteven/eclipse7.jpg http://i32.photobucket.com/albums/d24/omgitsteven/elcipse5.jpg http://i32.photobucket.com/albums/d24/omgitsteven/elcipse4.jpg http://i32.photobucket.com/albums/d24/omgitsteven/elcipse3.jpg http://i32.photobucket.com/albums/d24/omgitsteven/elcipse6.jpg http://i32.photobucket.com/albums/d24/omgitsteven/elcipse8.jpg |
