96 eclipse gst 18in rim problem
Old Nov 28, 2007 | 02:25 PM
JStrateger's Avatar
Default 96 eclipse gst 18in rim problem
I want to put 18 inch rims on my 96 Eclipse but there is a bar comming from my hub to my A-Arm that is stopping them from fitting from with tires, The bar is attached to the hub. what can I do to put these on?
Old Nov 28, 2007 | 02:28 PM
jlh077464's Avatar
Default RE: 96 eclipse gst 18in rim problem
Smaller tires.....But 18's should fit unless there huge tires, or the offset is way off.
Old Nov 28, 2007 | 03:04 PM
JStrateger's Avatar
Heres my problem.
http://www.megaperformance.com/catal...524/497288.htm
That's what Im trying to put on.
Old Nov 28, 2007 | 04:39 PM
jlh077464's Avatar
The red bar is your problem?....those wheels should fit....is it really hittin that bar or rubbing it?...
Old Nov 28, 2007 | 07:49 PM
shreff99's Avatar
I've got 18's on my '99 GS-T and they fit just fine. My tires are 215/35/18 and nothing rubs. What size tires are you running? Also what size wheels? Mine are 18x8.0 I think.
Old Nov 29, 2007 | 01:04 PM
5star's Avatar
I got 215/35/19 tires and 19 x7.5, + 42mm rims and nothing rubs.
Old Nov 29, 2007 | 03:11 PM
Kaede.Noir's Avatar
ive got 235/40/18 with no problems except rough rim ride
Old Nov 29, 2007 | 06:04 PM
shreff99's Avatar
how are you running 235's on an Eclipse??
Old Nov 29, 2007 | 08:31 PM
JStrateger's Avatar
The tires were already pretty small, I was going to buy the set with tires from someone for 150.00. I think I'll pass and get some 17". I've seen people with 19" fit on an eclipse, I just don't see how.
Old Dec 1, 2007 | 11:33 PM
_Adrian_'s Avatar
im runnin 245/40zr18...
no rubbing
its all about the right offset.
nothing that new studs and a spacer wont fix
