Eibach Pro Kit
Old Mar 9, 2006 | 02:32 PM
ziggy88's Avatar
Default Eibach Pro Kit
Thinking about getting that kit. My buddy has it on his SRT-4 and it rides pretty smooth. Should I get the springs or look into coilovers etc.?
Old Mar 9, 2006 | 03:51 PM
Default RE: Eibach Pro Kit
Real coilovers cost about $1100. the cheap ones will not ride good at all. If you get springs you should get a camber kit for all wheels and KYB AGX shocks\struts. Other wise like I said stay away from the cheap coilovers they will kill you
Old Mar 9, 2006 | 04:58 PM
ziggy88's Avatar
How much would a camber kit cost? Do you know?
Old Mar 9, 2006 | 05:08 PM
ORIGINAL: ziggy88
oh im not sure I havent ever bought one. I lowered my GS with goldline springs 1.5 in drop and had KYBs but the camber wasnt bad so I never ended up buying the camber kit
Old Mar 10, 2006 | 01:15 AM
ziggy88's Avatar
ahh....I see. Well i'll have to look into that then. Is the camber really that bad on a 2g to get a camber kit? Just wondering
Old Mar 10, 2006 | 09:35 AM
ORIGINAL: ziggy88
well your tires wont last as lon with out it and the wheels will have an angle that looks funny
Old Mar 10, 2006 | 10:52 AM
i don't think if you just get the eibach springs you will need a camber kit. I you get coilovers you definetly need one, but i think the springs only give you about a 1.2" drop which isn't too bad. Its definetly a good kit though.
Old Mar 10, 2006 | 03:52 PM
ziggy88's Avatar
ok so that kit is recommended?...Also how much is handling going to differ from stock. Will handling and cornering be improved or about the same?
Old Mar 10, 2006 | 06:19 PM
your handling will greatly improve over stock. Especially with that kit.
Old Mar 10, 2006 | 06:40 PM
ORIGINAL: TheEngineer
one gives a 1.2 I think and the other is 2.0
and your handleing will be AMAZING after youll love to drive it around the bends
