endeavor wheel vibration
Old Apr 15, 2012 | 03:29 PM
nate_nauman's Avatar
Default endeavor wheel vibration
I have a 2004 endeaver with awd. I have a vibration in the front end that starts as soon as i start to accelarate and gets worse the faster i go, also gets worse when i turn left. I have replaced the left front wheel hub assembly, no fix. I have jacked up front end and hand checked the wheels bearing and tire rod by checking up and down, left to right play and there is no play in the tires. I thought it might be a tire issue so i rotated the tires to the back and the problem still exist. I would appreciate some help.
Old May 31, 2012 | 11:11 PM
mxmikie's Avatar
Wheel Alignment / bad tire / axle
Yury
Feb 8, 2025 06:40 PM
n0c7
Jun 27, 2016 03:19 PM
ChevyBoyUSA1
Aug 11, 2015 04:51 PM
SERPENTOR
Oct 10, 2014 03:16 PM
athlete1012
Aug 19, 2008 06:45 PM
