-   Suspension (https://mitsubishiforum.com/forum/suspension-27/)
-   -   endeavor wheel vibration (https://mitsubishiforum.com/forum/suspension-27/endeavor-wheel-vibration-42154/)
nate_nauman Apr 15, 2012 03:29 PM
I have a 2004 endeaver with awd. I have a vibration in the front end that starts as soon as i start to accelarate and gets worse the faster i go, also gets worse when i turn left. I have replaced the left front wheel hub assembly, no fix. I have jacked up front end and hand checked the wheels bearing and tire rod by checking up and down, left to right play and there is no play in the tires. I thought it might be a tire issue so i rotated the tires to the back and the problem still exist. I would appreciate some help.
mxmikie May 31, 2012 11:11 PM
Wheel Alignment / bad tire / axle
