Front end also shaking
Old 06-19-2006, 12:13 PM
Sands128's Avatar
Default RE: Front end also shaking
Oddly enough i found out the problem, i kinda laughed when it happend, then realized i was semi-stranded, on my way home from work thursday night the shaking got worse as i drove on, then all of the sudden it shook real hard, and i heard a loud, POP turns out my drivers side front tire had a knot in it and my tire blew, so it wasnt the right side at all but drivers side bad tire heh go figgure, it was a smooth ride home with a doughnut on, (this just makes it an easier and quicker process twards putting on my 17"s) thanks again guys for all the help !
Old 06-20-2006, 01:40 AM
A lil more info on this, I had my tires balanced again the other day...of course they were not balanced right the first time, by the people who do it for a living. So they rebalanced the tires and the guy just now noticed that my rims need a special ring that allows it to be hub-centric like the stock rims. I guess the wheels aren't going onto the hub perfectly center. I thought that the lugs would center the rim, but apparently not.
ajl44
03-23-2014 10:04 AM
Simss
02-21-2007 07:33 PM
SPELMANITE84
09-18-2006 09:15 PM
ictponder
06-16-2006 11:31 PM
cdipier2
08-09-2003 04:13 PM
Quick Reply: Front end also shaking
