strut ? camber issue
ok my camber is about 4 degrese off "top of tire is out more than the bottom" would this be a sign of a bent strut?
also what is a good strut to get for a resonable price preff under 90$ ea |
RE: strut ? camber issue
do you have lowering springs, aftermarket coilovers?
no!
well if the strut is bad then you would have alot of banging. This seems like some kinda other suspensoin issue, like a joint or something
well i took it appart today and nothing is bent"or looks bent" i did replace the tie-rod on the passenger side "thats the side i am having all the trouble" when i brought it in to get it all lined up the said they couldnt help me, so i went to another shop and they said that it might be a strut , so pretty much i am lost and am replacing stuff till it goes away. so any help on this one is awsome
the only other thing that i thought of is that the frame might be bent a little. that that just happens by bending it from on side to that other, nothing that i heard of it messing up the camber.
well i went to replace the upper control arm, and i noticed that one of the mounting bolts was pushed through a little, so i put in a new upper control arm and put in a washer between the car and the controll arm , it semed to make it a little better so i am going to take it up and see if the can alighn it now.
thanks for the tips! |
well i was talkin to some guys down at our local spot's, i didnt know that the eclips has non adj camber so they told me it's most likley a bad spring. how does this sound to you guys
