Side mirror
Old Jun 2, 2020 | 02:37 AM
cml181's Avatar
Default Side mirror
Does anybody know if a 2010-2015 ASX side mirror will fit my 2012 Outlander suv ?
Old Jun 2, 2020 | 10:15 AM
AWCAWD's Avatar
Yes and no. Mechanically they are the same but the connectors are different. You can make it fit if you cut the wires and reconnect with your correct connector. The color codes are the same (at least in the models I found). Please read post #12 in this thread for pictures. Good luck.
Old Jun 2, 2020 | 11:08 AM
cml181's Avatar
Thanks for your help .its the difference between £82 and £165 so you info is valuable.
Old Today | 04:22 AM
smithbrown's Avatar
There's a good chance they could be compatible since both share similar Mitsubishi platform genes during that era. If you want properly fitted utv mirrors that bolt right on without guessing, double check the part numbers before buying. A quick search on RockAuto or a Mitsubishi dealer confirmation will save you the hassle of a return!
Cobra_427
Mar 8, 2024 02:44 AM
joe603
Jan 13, 2010 08:03 AM
subhdey
Apr 3, 2008 09:35 AM
rsk135
Feb 20, 2008 06:48 PM
barrytate6
Sep 11, 2007 10:09 PM
