boost gauge and controller
RE: boost gauge and controller
Gauge- http://www.vfaq.com/mods/wayback/Bra...ges/boost.html
The controller (if manual), will tap into the rubber line between the wastegate actuator, and the turbo like this
thanks for the help but i started researching and one site said to close off the turbo compressor housing is this true cuz in that pic jeff posted the turbo compressor housing is connected to the controller is this right?
Search here...I have posted how to do this install 10 times with pictures atleast 3 pictures in the threads.
One hose will connect to the compressor housing and the other to the waistegate and then you losen the screw of the MBC and you lower boost you tighten to up the boost.
