boost gauge and controller
Old May 8, 2006 | 11:15 PM
2nd g eclipse gst's Avatar
Default boost gauge and controller
can neone give me some links or pics on how to install the boost gauge and controller i know its been explained many times i have a 95 eclipse gst thanks
Old May 9, 2006 | 01:16 AM
n2daizo123's Avatar
Default RE: boost gauge and controller
what kind manual or electronic?
Old May 9, 2006 | 02:30 AM
5Tizzle's Avatar
Gauge- http://www.vfaq.com/mods/wayback/Bra...ges/boost.html
The controller (if manual), will tap into the rubber line between the wastegate actuator, and the turbo like this
Old May 9, 2006 | 04:10 AM
agallardo's Avatar
Is that all you need to do in order to install a manul boost controller? As shown in the picture above.
Old May 9, 2006 | 04:15 AM
5Tizzle's Avatar
ORIGINAL: agallardo
yeah
Old May 9, 2006 | 04:45 PM
thanks for the help but i started researching and one site said to close off the turbo compressor housing is this true cuz in that pic jeff posted the turbo compressor housing is connected to the controller is this right?
Old May 9, 2006 | 08:49 PM
can any one give me some advice asap im alittle confused and i want to get it finish today thanks
Old May 9, 2006 | 11:53 PM
Search here...I have posted how to do this install 10 times with pictures atleast 3 pictures in the threads.
One hose will connect to the compressor housing and the other to the waistegate and then you losen the screw of the MBC and you lower boost you tighten to up the boost.
Old May 10, 2006 | 12:32 AM
agallardo's Avatar
A little off the subject, but what does the turbo timer connect to? Where does the harness connect to?
Old May 10, 2006 | 12:42 AM
93eclipsegsx's Avatar
the harness goes inbetween a connection for your ignition, and also connects to the e-brake wire that tells you that your e-brake is on.and the timer connects to the harness
