NEED OPINION
Old 04-21-2006, 01:54 AM
Dookitchen's Avatar
Default NEED OPINION
Hey guys, I have a MItsubishi Eclipse GS 1995 FWD with 148.000 miles on it. So far I've spend some money on the car and I need some opinion if I should sell it or should I keep it.
I change the transmission, new radiator, new powersteering pump, new struts (2 front and 2 rear), new upper knuckle bushings, new tires, rebuilt top end engine, K&N filter, new Header, new rotors ( 2 front and 2 rear)
Pioneer cd player with 3 channel amp alpine and sony Xploid 10" subwoofer. Right now I'm working on the ECM. I getting a new one in about a week and change out the old one with the new one. I think I'm the third owner and I've been taking care of this car like my own son. I maintain on oil changing every 2500 miles. check tire pressure every month. Always has half a tank of fuel at all the time.
How many miles would this car last to?
if the answer yes I should sell, how much should I sell?
Thanks guys!!! I appreciate it
Old 04-21-2006, 02:38 AM
Default RE: NEED OPINION
in my opinion, you shouldnt sell your car. since you throw quite a bit of money into it. and if you sell it now. people wont really give you a high price for it. you should keep it. and if you keep doing the oil changes. it should last quite long.
Old 04-21-2006, 09:48 AM
that engine should last you a while. It sounds like its pretty well maintainted. So i dont see you really having a problem with it. Obviously becuase its getting up there your still probably going to have general maintenance but i doubt that the car will die on you. The best thing i think to do is to do a compression test and see how well the motor is performing. If thats fine then your good to go.
Old 04-24-2006, 06:16 PM
Dookitchen's Avatar
All I'm wishing for my car is to last till nearly 200.000 miles. That's should be around 3 years from now. Do u think it will go up there? if the motor is still ok because I didn't do anything with the lower part of the engine
Old 04-24-2006, 11:30 PM
93eclipsegsx's Avatar
i had a 90GS and it had 191,000 miles on it and the kid i sold it to blew up the trans doing burnouts and i dont know what he did from there.
nastynate
08-31-2007 04:24 PM
I Drive Naked
07-02-2007 09:22 AM
illvibe311
05-20-2006 11:10 AM
Yayirobe
05-02-2006 07:10 PM
Quick Reply: NEED OPINION
