Problem
Problem
Motor- 4G63-T w/ manual trans.........Okay, so I was going to see my girlfriend yesterday when I heard an odd noise. I didn't think anything of it but then I heard a kind of large clunk and I knew exactly what it was. My belts had slipped off there pulleys some how and I really can't explain how it happened. So anyways, as I was driving, all my dummy lights came on and stuff but the car was still running. I had lost my power steering of course being that the belt came off and I had to muscle the car to the side of the road. I loosened the alternator and put the belts back on. I was all happy and stuff until I got in to the cab and turned the key. Nothing. I sighed, popped the hood again and was looking around and checked the ignition fuse. Blown. So I was like no big deal, I will go to Napa tomorrow and get one thinking that it had just blown for some retarded reason. Get a new fuse, put it in. Nothing. Now I talked to my local mechanic and he asked whether anything had frayed or anything but I couldn't see anything out of the ordinary and I went around that whole side of the car with my snake light. He said, "Well, it sounds like your starter is still engaged. What I want you to do is put it in gear and try and get that starter where it needs to be because it's overloading that fuse." I am not really sure on anything electrical. Anyone's help would be appreciated.
RE: Problem
I got it started. One of the wires was frayed on the tachometer interface and I had it put a new connector on it. As far as the belt coming off I believe it's because the harmonic balancer is in two pieces at the moment. Has that ever happened to anyone? It's the pulley that is on the very bottom of the motor and is connected to the crank. On Chevys that is the harmonic balancer but I wasn't sure if this was one or not. I would take a picture, but I can't seem to find my camera. Are the motors hard to time? I haven't done timing on this type of car before. When I got it started, the motor was shaking really bad but I didn't hear any pinging noises so I don't think I have a bent valve or anything. Again, let me know what you guys think.
RE: Problem
Yeah, I ordered the part from Napa, they get it in the morning, hopefully it will stop raining long enough for me get what I need to get done. It also requires a puller unless you know of some other way. I was also looking the repair manual, do I really need to remove the engine mount or can I just remove the driver's side tire and get it out that way?
RE: Problem
See, I would do that, but there are other things that factor in besides those four bolts. Don't I have to take off the retainer that holds the pulley on the crankshaft. Also, when I went to take off those four bolts in my first attempt all that happened was the pulley started turning and engaging the crank. Is there a way to stop this from happening? I don't really want to lodge anything in there and mess anything up. I appreciate all the help though.
