safe boost level
Old 04-18-2005, 11:09 PM
1998blackgst 240's Avatar
Default safe boost level
Right now im running close to 13 psi stock turbo on my 98 gst. how much psi can it reliably handle . i heard 15 but i just wanna be sure
Old 04-18-2005, 11:24 PM
Default RE: safe boost level
You can run 15 safely, some ppl I know run 16-18 PSI, but thats probably not the safest boost to run.
Old 04-19-2005, 12:28 AM
DSMTalonAWD51's Avatar
15 stock is fine. up to 17 on stock turbo with bigger fuel pump.
Old 04-19-2005, 06:26 AM
You're altitude is a factor aswell. I personally live in CO roughly 5.2k feet or 6.3k at the local track. 2.5k feet = 1psi roughly. Since 14.7psi is natural pressure at sea level and at 5280ft it is 12.5 +/-
Old 04-19-2005, 12:35 PM
anything safe for sealevel will be even safer up in the mountains. ex 15psi will be less dense in the mts so will actually be a little slower than 15psi at sea level. altitude is a factor for safety yes, but psi is psi no matter where you are you can still set your boost controller at 15psi.
Old 04-19-2005, 08:01 PM
alright good cuz i wanna get a boost controller and set it for about 15. thanks alot
cheeks97gst
01-16-2012 08:23 PM
Gstfat
06-12-2007 12:43 AM
big_will
11-02-2005 10:06 PM
turbobird14
08-08-2005 10:37 PM
Tmann26
12-02-2004 09:55 PM
Quick Reply: safe boost level
