Torque specs
Old 06-07-2006, 07:26 PM
Nubiebubie_GSX's Avatar
Default Torque specs
Hey, just a quick question. Would anybody be able to tell me the torque spec for the head and manifold. I ordered a chilton manual and its going to be about 2 weeks before it comes in. Just thought iwant to start on it before that. Thanks
Old 06-07-2006, 07:58 PM
93eclipsegsx's Avatar
Default RE: Torque specs
51-54 foot pounds for the head to block.
Old 06-07-2006, 09:34 PM
Straight from chiltons-
Exhaust Manifold= 18-22 pounds
Old 06-09-2006, 05:21 AM
ALLDATA shows 72ft/lbs for the head bolts
Old 06-09-2006, 07:39 PM
oh, thats what i got out of my book. 51-54 + 1/4 turn
Old 06-10-2006, 06:40 PM
Thanks all.. now i just hope i have a bad gasket and no crack manifold or something serious.. c ya
Old 06-10-2006, 08:00 PM
What was the problem? Sypmtoms? Comression test?
Old 06-10-2006, 09:25 PM
2 be honest there alot of problems. but the main thing is its missfiring. missfire a bit during idle and alot when i cruise between 2-3k rpm. There an exhaust leak on the top right side of the manifold. You can feel the exhaust pushing out of that side. I am full spooled at nearly 4.5k around. I was told i might have a boost leak or vacum leak. I just need to find out if i do have it , where its coming from. Also 3 engine error code, which i was told from the mitsu dealer that its caused due to the purge solenoid not hooked up i guess, missfire, and MAP sensor or something. .Kinda forgot. soo i kind of have my work cut out for now. Suck cuz i just bought it used and already there alot of things i need to do.
agallardo
02-22-2007 01:57 PM
agallardo
01-29-2007 01:10 AM
fergymoto
01-15-2007 03:38 PM
Reuben
04-25-2006 02:12 PM
bobdilts
11-14-2005 02:44 AM
Quick Reply: Torque specs
