Sponsored by:
Sponsored by:
transmission not shifting into overdrive
Old 04-24-2004, 09:25 PM
glenn's Avatar
Default transmission not shifting into overdrive
</P>
I test drove a 1992 mitsubishi cube van today,auto transmission, it does not go into overdrive. Im not sure where to start to see if it is worth buying and fixing. I would invest as much as $1000 into the repair. everything else sounds and feels good in the transmission. The shift stick also has a overdrive button on it. </P>
</P>
Thanks glenn</P>
Old 05-13-2004, 04:44 PM
overdrive cluthpack burnt ....not that bad of a job check your local trans shop also ask the dealer compare prices then go to your local shop with the parts in hand
Old 05-13-2004, 04:46 PM
DID YOU push the button ?<IMG src=smileys/smiley4.gif border="0"><IMG src=smileys/smiley4.gif border="0"><IMG src=smileys/smiley4.gif border="0">
97teg415
08-13-2009 01:07 PM
diskretephx
02-02-2007 10:15 AM
Riktar
01-14-2004 05:38 PM
crackhead365
10-27-2003 05:31 AM
Eclipse95
10-01-2003 05:28 PM
Quick Reply: transmission not shifting into overdrive
