Stock, Stroker, Destroker, what does it all mean???
Old 01-31-2007, 11:28 PM
Default Stock, Stroker, Destroker, what does it all mean???
A lot of times people throw aournd the words stroker and destroker without really knowing for sure what they mean. Well, now you'll know...
For a better understanding of how these motors work...
A STOCK 4G64 has an 86.5mm bore and 100mm stroke
A STOCK 4G63 has an 85.0mm bore and 88mm stroke
The bore is dictated by the piston/block selection. A motor can be bored out 0.5mm safely, but I wouldn't go beyond that for the sake of sleeve thickness.
The stroke is dictated by the crank. The cranks are interchangeable between the two motors.
For reference... there are 1000mm^3 (cubic millimeters) in 1cc (cubic centimeter). There are 1000cc in 1L (Liter). Therefore, there are 1000000mm^3 in 1L.
Stock 4G64:
Lets do some math...
An 86.5mm piston has a cross sectional area of ~5877mm^2 (pi * radius^2), times 4 pistons is ~23508mm^2, times 100mm stroke is ~2350800mm^3 which is ~2.35L or 2.4L. That is how a 4G64 is considered a 2.4L motor.
Stock 4G63:
An 85mm piston has a cross sectional area of ~5675mm^2, times 4 pistons is ~22700mm^2, times an 88mm stroke is 1997600mm^3 which is 1.99L or 2.0L, pretty simple, right?
To STROKE a 4g63 you put a longer stroke crank in it. A 100mm crank from a 4G64 has a 12mm longer stroke than the stock crank.... do the math again.
4G63 STROKER:
An 85mm piston has a cross sectional area of ~5675mm^2, times 4 pistons is ~22700mm^2, times a new longer 100mm stroke is 2270000mm^3 which is 2.27L or 2.3L. So to get a 2.3L stroker, you must install a 4G64 crank into a 4G63 block.
You CANNOT DEstroke a 4G63 because there is no shorter stroke crank readily available!
You CAN DEstroke a 4G64 with a 4G63 crank! Do the math again....
4G64 DEstroker:
An 86.5mm piston has a cross sectional area of ~5877mm^2, times 4 pistons is ~23508mm^2, times a SHORTER 88mm stroke is ~2068704mm^3 which is ~2.06L or 2.1L. So to make a DEstroker, you must use a 4G64 block with a 4G63 crank
Why do this?? The destroker is essentially a 4G63 with a taller deck height (read: londer rods decrease the rod angle creating less cylinder side loads = higher RPM tolerance) and punched out 1.5mm for a bit more displacement.
Borrowed from NE-Evos.net written by: SuperHatch
roadkill1975
05-13-2010 10:51 PM
someguy1984
01-22-2009 11:09 PM
ECLIPSE74
03-04-2008 03:54 AM
Silver00GT
08-26-2007 07:40 PM
coliphage
02-18-2005 09:46 AM
Quick Reply: Stock, Stroker, Destroker, what does it all mean???
