Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
01 Diamante tranny problems - Heater core?
Old 07-02-2009, 10:14 AM
voodo1's Avatar
Default 01 Diamante tranny problems - Heater core?
Hi, 01 Diamante w/134K miles. No problems at all until this week.
2 days ago, my transmission would not go into drive for 5-8 seconds after starting the car in the morning.
I checked the transmission fluid and it was a little low, so I topped it off - no change.
If the car is "cold" (it is summer), if I pull up to a stop and the RPMs get below 1K, the transmission kicks into N. If I brake and rev it up, it will kick back it.
Once the car warms up (5 minutes) the transmission stays engaged.
I have read about the heater core issue and am wondering if this isn't the issue but I have no wet carpets and there isn't a smell. There is a bit of film on the inside of the window. (but I haven't washed it in a while)
The trans. fluid doesn't smell burnt and is still red.
Any ideas?
Old 07-06-2009, 10:35 AM
darcymicro's Avatar
If you not have replaced the trans fluid at the proper intervals, replace fluid; only use OEM dealer fluid; do not use trans flush machines with claimed Mitsubishi equivalent additives that shops will tell you works fine; it does not work.
You would certainly smell the glycol inside the car if the film on the windows was from coolant leaking from the heater core seals, so this is probably not the issue.
Old 12-04-2009, 08:32 PM
voodo1's Avatar
Default Pulled error code P10732 - any chance it is electrical only?
After months of messing with this, it is at the transmission shop now. They pulled P10732 (incorrect 2nd gear ratio) after "racing" the transmission.
I obtained a second ECU and immobilizer that I haven't put in yet just because the dealer wants $135 to program the keys and I have to tow it over there.
Any chance it is an electrical issue (ECU, input speed sensor, etc) or should I assume this is going to result in a $3K transmission bill?
Thanks.
bloms433
11-22-2010 07:00 PM
ryan51173
09-19-2010 11:39 PM
jhny7
01-03-2006 01:36 AM
bcolins
05-23-2005 09:50 AM
Quick Reply: 01 Diamante tranny problems - Heater core?
