Go Back   Mitsubishi Forum - Mitsubishi Enthusiast Forums > Mitsubishi Models > Mitsubishi Montero & Montero Sport
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Mitsubishi Forum - Mitsubishi Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 10-02-2009, 12:22 PM
Default 2001 mitsubishi montero codes
hi last month the check engine light went on i found out i had a p0155 code the 02 sensor so i left it. then i had a fire in the engine not bad just the cap was left off after the oil change and i drove for a while until i saw smoke oil was spraying on the exhaust shield. there was a small fire on the shield so someone sprayed a fire extinguisher in there but it got all in the valve cover. so i had it towed to a garage the cleaned everything out and changed the oil.
now after a week or so i go to emission and fail i got two new codes now p0173 and p0170 is that from the fire and what are they
This ad is not displayed to registered members.
Register your free account today and become a member on MitsubishiForum!
Old 10-02-2009, 01:49 PM
P0170 Fuel Trim Malfunction (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
There are a lot of problems that can cause these codes to show up but the most common is a vacuum leak. Maybe something melted?
__________________
- 2003 Montero Sport XLS AWD (current)
- 2012 Honda Pilot EX AWD (current)
- 2006 Nissan Altima SE-R (current)
- 1999 4X4 Montero Sport Limited (retired)
- 1997 4x4 Montero Sport XLS (retired)
- 2003 Galant LS (retired)
- Lots of cars and SUVs before that
Old 09-27-2010, 08:15 PM
Hello,
I'm curious to find out if you were able to clear the codes. What was causing the codes to come up?
Tags
02, 1999, 2, 2001, bank, check, code, engine, fuel, light, malfunction, mitsubihi, mitsubishi, montero, p0173, problem, sport, trim
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
