Pajero/Montero MMCS reverse camera
Old Sep 27, 2010 | 04:28 AM
bsabuktr's Avatar
Default Pajero/Montero MMCS reverse camera
I made a cable connection to the top right socket with 3rd pin to camera video line, 5 and 6th pin together to the camera ground.Took 12volt connection for camera module from the reverse light and grounded camera to the vehicle body. now the MMCS and camera is connected. But when i put the vehicle in reverse, the reverse image is not appearing on screen.But when i go to the camera settings menu, i can see the reverse image.is there any connection left to be made?when i check the "network line settings" in the mmcs by using set+navi button, all are showing OK(camera,GPS,dvd...) except video in. is there anything else to be done?
Attached Thumbnails Pajero/Montero MMCS reverse camera-rear2.jpg
Old Sep 27, 2010 | 03:10 PM
redturboeclipse's Avatar
What year is your Pajero? I'm assuming it is one of the newer one taht uses the same if not similar MMCS system as the 07+ Outlander. Their forums have a lot of info on the MMCS system you may want to refer to.
Old Sep 28, 2010 | 02:27 AM
bsabuktr's Avatar
Default 2009 pajero
I am having 2009 pajero. MMCS which i got is same as the outlander one with 30gb hard disk.
Old Sep 28, 2010 | 02:49 AM
Yea then you may want to go to their forums, or go to Au. Pajero forums as they continue a good forum fan base for pajeros newer than 3rd gen. Here in the USA we no longer get the Montero/Pajero
redturboeclipse
Aug 26, 2020 04:51 AM
CaptnKebec
Apr 19, 2014 12:30 PM
rapps101
Feb 16, 2014 01:39 AM
Vaughn
Jan 14, 2008 02:02 PM
