Pajero Oil Flow
Old 06-09-2016, 11:00 AM
rogerbotswana's Avatar
Default Pajero Oil Flow
I have a 2002 Pajero (Montero in US I think) 75W with a 6G74 3.5L V6 engine 24valve…. (Jap import)
does anyone know where I can get or look at an engine oil flow diagram... I am trying to figure out where the oil comes from to set the pressure for the pressure switch?
Am I right in saying the the oil sits in the sump and then gets sucked up the oil pickup pipe... through the rockers and then down to the oil pressure switch?
would that be correct?
Thanks
Old 06-09-2016, 04:57 PM
larry4406's Avatar
Negative
Pickup in sump to pump thru filter extension with pressure tap for gage/sensor, main block galley where it goes down to bearing feeds and up to heads where then into rocker shafts and cam bearings. Fromm rocker shafts into rockers thru the valve lash adjusters.
rax
10-06-2011 07:38 AM
1rippinGT
04-02-2004 11:43 AM
ListenersAudio
02-22-2004 05:25 PM
Bong
08-22-2003 08:21 PM
Quick Reply: Pajero Oil Flow
