90 Montero 3.0 ignition problem
Old 01-28-2008, 10:52 AM
bassmankws's Avatar
Default 90 Montero 3.0 ignition problem
I have a 90 Montero 3.0L. The problem is in the ignition. I can put the ignition switch in the run position, without starting the truck, and there is ignition spark coming through the coil wire to the cap constantly. It is a very rapid fire spark. I had the ignition module checked and it tested fine. Any help would be appreciated greatly.
Old 02-01-2008, 11:35 PM
jgbrules's Avatar
Default RE: 90 Montero 3.0 ignition problem
hello! sounds like the electrical part of the ignition switch is bad. sending the start signal at the wrong time. those switches are not very expensive. mabey even find a used one at a wrecking yard to test and see. good luck! greg...
allallyouyou
02-12-2012 11:13 PM
czabala
01-26-2007 06:59 PM
copperboard
04-17-2006 11:04 PM
copperboard
04-05-2006 10:23 AM
pilot
01-14-2006 10:42 PM
Quick Reply: 90 Montero 3.0 ignition problem
