2011 Hood strut kit.
Old 12-22-2011, 09:44 AM
Vadimus's Avatar
News for 2010+ owners. Now it looks like there's another way to have a hood dampers.
Instead of using those custom parts I ordered from distant Moscow,
there is a simple solution by Zuht:
All you need to do is to attach 340 N rated 60cm (24") tailgate struts as on these pics. No drilling required, just 4 nuts and 4 showers.
Old 12-22-2011, 12:50 PM
milliesdad's Avatar
I thought of this, but the right side has a square hole for the washer hose clip.
You have PM
Old 12-22-2011, 01:45 PM
Vadimus's Avatar
Well, then another washer hose attachment is needed.
Old 07-29-2012, 12:05 PM
Vadimus's Avatar
Here is how sprinkler tube is hold with mountless dampers:
Old 07-29-2012, 01:39 PM
firebirdrc's Avatar
Great Thread !
This mod was the easiest I had ever done.
The difficult part was to find 60 cm Gas struts :-)
Old 07-30-2012, 06:58 AM
milliesdad's Avatar
Smile
Thank you for the pictures.
I did this, but make an upper mount and have then secured on the bottom in the third hole down on the fender.
This is a much better setup than what I devised.
Mike will be changed real soon.
Old 08-01-2012, 06:46 AM
milliesdad's Avatar
Thank you Vadimus.
I went to my favorite parts store, got the Strong Arm brand of lift support, part no. 4782. you also need 4 10mm ball studs, 4 nylon insert locking nuts and 8 flat washers. I cut a piece of fuel line hose length-wise (about 6 in) to put around the washer hose befoe using a wire tie to secure it out of the way.
Works very slick, looks better than all the adapters I tried with my 21 in supports and have just the right amount of frce.
Old 08-01-2012, 02:48 PM
Gen-8's Avatar
I used simple Legnum tailgate boot struts and rivnuts and voila
Old 08-01-2012, 04:35 PM
OutlanderGT's Avatar
Thank you Vadimus.
I want to do this.. so there is definitely clearance to fit these? No dents or be visible when closed?
Does it make it harder to close the hood with the structs installed?
And where do I get the ball studs?
Thanks
Old 08-02-2012, 07:12 AM
milliesdad's Avatar
there is a website that has everything that you could ask for in the way of gas struts, but I can't find it now.
There is no interference what so ever, and they are not visable form the otside with the hood closed.
Fifteen minute job.I find that the Strong Arm brand works perfectly, just a the right amount of assist.
Quick Reply: 2011 Hood strut kit.
