Replace your OE Rearview Mirror - Install pics here
#31
I am still using clip on and it's ok for the most part, but I do really want all in one solution. Is there an easier way to get these installed like on rav4?
http://rav4world.com/mods/4.3/interi...ng_mirror.html
#32
GENTEX Super Mirror
My new interior mirror. Has same features that my previous model, more power red light (instead of green), illuminated bottons, nice blue ambient light and cover for hide the wires. . .
UPDATE: No HomeLink system available in this model
#33
RE: Replace your OE Rearview Mirror - Install pics here
Great instructions! Installed a Gentex GENK45a Auto-Dim w/homelink and compass this weekend. Works Great and the install was pretty easy thanks to the detailed instructions. I tried tapping into the dome light, but could not find the ignition wire, so to the fuse box I went. It was a nice surprise to find out the panels come off (and back on) so easily. Total install time (including the dome light detour) was about 3 hrs.
#35
Interior mirror with illuminated bottons
What is model and where did you buy it ?
#36
Hi Greg. Look by cali4-Mayjorge-003 and 004 here:
http://www.japanparts.com/db/partsli...cali4-mayjorge
it´s GENTEX Supermirror and is sold in Japan, and you can choose between 4 light color, white/blue/red/green for buttons and power supply LED. Remember, no HomeLink available with this mirror
#37
I decided to junk the factory rear view mirror and install a nice Gentek Auto Dim w/Homelink rearview mirror kit. I was sick of fumbling around with my garage door openers(one for home, one for the office) which I kept in the centre dash top storage box. This mirror also autodims electronically which isn't really necessary given we have tinted rear glass, but its still cool! I managed to find an OEM kit on e-bay for $139 so I ordered it.
First step was removing the old mirror. There is a plastic "dressup" cover which needs to be popped off first. It has two claws on either side but you can pry the sides up and over the catch with a small flat tool/scredriver to release. Once released, slide the cover down the arm and out of your way. Here is the plastic cover I am talking about:
Once you have the plastic cover out of the way, hold your screwdriver perpendicular to the fron windshield and push the tab on the bottom of the locking mechanism towards the front windhield to release the locking mechanism. While pushing the tab, slide the mirror assembly towards the roof headliner to remove.
Here is the glass mount wedge button on our Outies - note when buying rear view mirrors there are wedge and cam lock versions of the connectors. You want a wedge compatible mirror.
Here is the kit I bought. It allows up to three remote controllers to be programmed in.
Next step was to locate a suitable connection point. This partciluar mirror has two 12volt inputs (one for the AutoDim and one for the Homlink system). The Homelink system I wanted on constant power although some may prefer switched power for increased security. Last I need a suitable grounding point.
Looking at the fuse box I find on the ETACS connectors, connector C-317 has constant 12 volts and terminal 1 and swithed 12 volts at terminal 7. There is also a ground wire at terminal 15 but I prefer a hard ground point. Here is the connector and wires I tapped for power:
Now its time to pull some plastic. I removed the leftside vent cover, popped open the front pillar cover (full removal is not necessary), removed the trim piece below the front pillar and that is it. There are no screws, only pop fasteners, with the exception of the bottom trim piece which extends all the way forward to the dead pedal foot rest. There is a bolt coming through the floor which secures this trim piece with a plstic slide nut - you can just pop it off. I don't have a pictur of it but you will see it and can easily remove it. Here is the front pillar cover popped off you can pop it off by squeezing with you rhands at the edges, no tools required):
Here is where the lower trim was removed:
Once the lower trim is out of the way, you can find the grounding spot by pulling back the carpet next to the dead pedal. Its a 10mm bolt.
Okay time to route the wiring and make this look like a professional installation. The wiring harness has a connector which plugs into the back of the mirror. Starting near the mirror location, you can tuck the wire up and under the headliner using your fingers. Work your way towards the front pillar cover.
Once you get to the front pillar trim, bring the wire out from the headliner (there is a huge opening here), and work the wire behing the front pillar trim.
Okay so now all your wiring can come out at the bottom fo the front pillar where the bottom trim has been removed:
I tapped T-Connects into the wiring harness C-317 (as noted in the picture above) for the constant and switched power and connected the yellow wire from the harness to the constant power (teminal 1)(for Homelink ops) and the red harness wire to switched power at terminal 7. It is easier to tap if you unplug C-317 first:
That's it, that's all there is to it. Now just dress up the wiring on the window glass at the mirror location with the included wire cover and test it out:
Good luck, it works great and now I have no remotes in my car anymore!
#38
Hallo,
I have ordered a mirror at Advance MCS Electronics. The package has reached at monday. Today I have installed the mirror. Thanks a lot to this post, it was a greet help for me and the installprocedure was very easy. The mirror is a Gentex GenK 5A with only compass. I don't have a garage, but only a carport.
Thanks and best regards from germany
Egbert
Egbert
#39
Just finished my Gentex/Homelink mirror install... 2 hours. Works perfect.
My thanks to "rdenis" for his original post. Would never have tried it without the great work he did.
Thank you, thank you...
Mike
Mike
#40
rdenis, how did you pulled out front pillar trim? Is it save to do that? If you have any suggestions, please reply in https://mitsubishiforum.com/forum/mi...-2013my-46879/
