wastegate actuator question..??
Old 05-03-2004, 06:07 PM
devildicer's Avatar
Default wastegate actuator question..??
just had a quick question about the Mitsubishi TD05-<B class=highlight>12a[/B] turbocharger...</P>
i'm a honda guy, so i don't really kno much about DSM turbines or motors for that matter heh...</P>
my understanding is that this turbo stock has an internal wastegate setup...so i was curious about what boost the internal wastegate is set at (i'm assuming 12 lbs from the "12"??)...in addition to that i was wondering about this turbo's wastegate actuator...'cuz i figure it doesn't really matter what the wastegate spring is set at...the actuator has the actual and final say as to what boost gets sent to the intercooler...so yeah...more importantly, what boost level is the 12a's wastegate ACTUATOR set at??</P>
thanx, ur help is much appreciated!!</P>
Old 08-13-2004, 02:39 AM
Default RE: wastegate actuator question..??
I'm not sure what the boost level is set at but what kind of cars does a 12a come off of?
Also if the wastegate arm is right I can show you a way to make it adjustable. I'd need to see a pic tho.
jerusry
01-02-2007 11:36 PM
oasis
01-23-2005 05:43 PM
override1059
02-10-2004 09:37 PM
Som1Dies2Nite
12-01-2003 08:47 PM
2fast4u
09-06-2003 06:44 PM
Quick Reply: wastegate actuator question..??
