4 cyl. Galant Ignition coil. HELP!
Old 10-12-2006, 09:02 PM
mark65's Avatar
Default 4 cyl. Galant Ignition coil. HELP!
Can some one with a 99 or later 4 cyl. do me a big favor. I need to know the actual voltages going to the coil with the key on, engine off. there is just one connector with 3 wires. there should be 12 volts, ground, and I am unsure of the third wire. I will greatly appreciate if anyone can check there car. I have a wiring diagram, but it does not show actual voltages.
davidsdlck
12-22-2020 06:51 PM
cesargc
01-28-2012 06:05 PM
copperboard
04-17-2006 11:04 PM
butter03
01-16-2006 02:57 AM
visionstudios
09-29-2005 02:02 AM
Quick Reply: 4 cyl. Galant Ignition coil. HELP!
