loud clicking sound when pressing brake in P
Old Oct 30, 2008 | 11:00 AM
josh_raben1971's Avatar
Default RE: loud clicking sound when pressing brake in P
My mistake....you are correct. When I got in the Outie this morning I verified. It will NOT lock automatically...but will unlock when put in park.
Old Nov 1, 2008 | 08:52 AM
armymen's Avatar
did you pay for that fix ?
mine do that too
Old Jul 17, 2009 | 08:38 PM
blitzkrieg79's Avatar
Originally Posted by josh_raben1971
I just experienced this same symptom. One day the clicking was quiet....the next day it was LOUD.
So I brought it to the dealer on Monday....and today they tell me that the Outie requires a new shifter assembly. They have ordered it and it will be here next week. I am picking my Outie up tonight so I have a vehicle to drive until the assembly arrives.
So, this level of noise is not normal, and the shifter assemble is the culprit.
Did the shifter assembly replacement solved your issue? I am wondering if the shifter assembly after a certain time (after it initially wears out a little like after 3-6 months) starts the loud clicking.
Old Jul 21, 2009 | 08:05 AM
sarah56's Avatar
Default Advice
I think it's normal and happen to any one, You can replace it and then see it work or not.
Old Jul 13, 2010 | 09:10 PM
newoutlanderfan's Avatar
THe exact same thing happened to me today..I went put it in reverse, so I pressed the brake while it was in park and heard a really loud click! There is no way that click was there before.....So I kept pressing the brake and the click happened every time it was in park - and I also think it clicked when I turned the ignition off (not sure). The click is definitely coming from the shifter area.
Some of you say it's normal, and some say it is the shifter assembly and neds to be replaced....anyone know for sure? I don't want it to get worse....
Also, on kind of the same topic, do you guys find when in manual mode (V6), that it is a pretty hard shift from 1st to second? It gives a pretty good shake (even when warmed up). I am wondering if my transmission is messed up somehow, since it also clicks/ lighty clunks when shifting into reverse or drive from park...
Thanks all...
Old Jul 20, 2010 | 09:08 PM
ivanz's Avatar
Clicking is normal. The relay may fail with time and get louder/stop working eventually. It's not that expensive to replace, and can be overridden with a screwdriver in the worst case.
As for shifting from 1->2 manually, it sounds like you are not at a low enough RPM range. There is a big difference in gear ratio between 1st and 2nd...combine this with the low end torque of the V6 and the result sounds about right.
What I do is get the RPMs up to 3000 in 1st, let go of the gas for a second, change gears, and re-apply the gas. Of course I barely ever drive fully in manual mode, rather, I just use it for engine braking.
Old Aug 16, 2010 | 02:34 PM
Yachtie's Avatar
The loud click when in park is definitely not normal.My dealer told me it was a known issue and required a new shifter assembly. They ordered one and replaced it. Problem solved. Incidentally if it was not under warranty it's at least a $600 fix.
Old Aug 17, 2010 | 01:04 PM
Do you know if there is a TSB for that? ARe you in Canada?
Old Aug 17, 2010 | 02:28 PM
Yachtie's Avatar
Yes I'm in Canada.
The service guy said there was a TSB for it but i don't know the number and could not find it online.
He did phone for authorization to Mits before ordering it though.
Old Aug 17, 2010 | 04:33 PM
Yes I'm in Canada.
Any chance you are in Calgary?
