02 Diamante, Heater Core?
Old Nov 17, 2008 | 08:39 AM
mitsupartsman.com's Avatar
Default RE: 02 Diamante, Heater Core?
ORIGINAL: ryan51173
It helps to have alot of patience and be able to twist your body in positions you never thought you could be in.
Thanks for everyones help!
now you'll be ready for this....lol
Old Nov 17, 2008 | 01:22 PM
ryan51173's Avatar
Hey, Thats great! Sign me up.LOL
Old Apr 14, 2009 | 10:05 AM
darcymicro's Avatar
Originally Posted by ryan51173
Mitsupartsman you are correct. I also noticed after taking a closer look the new ones have a bevel on both sides.
To update, I have succesfully change out the old rings and have installed the new ones. I found a procedure on how to do the 0-rings. The instructions I obtained are pretty good. They note that it's for changing the O-rings and not the heater core itself. The O-rings I purchased right from the dealer. P/N MR927776 which (accordingly to the dealer) supercedes P/N MR925655. They are $4.00 each in my neck of the woods. Several things to reccomend for the weekend warrior who decides to take this project on. TAKE YOUR TIME! I craked the plastic on the evaporater unit upon removal, whichI repaired w/ 2 part epoxy upon completion of the project. The big blunder that I have no problem admitting to, was that I didn't clean up any risidual coolant around the H/C. When you detach the pipes from the H/C to gain access to O-rings you have some coolant spill out. Well, I should have taken more time to dry that up.
I put most of the hardware back to test the O-rings and started the car. I noticed several drips, alot at first, the about 2 min later, a little drip. I figuredI wasn't getting offeasy and it was my H/C. So, off I want, removing parts from the driverside & dash to gain access to my H/C. After 1 hr. of removing parts and being extremely upset, I said to myself, maybe what you saw dripping was risdual coolant.I took a towel and cleaned up anything that resembled a drip on the floor. In went the key and the car ran for 20 min.. Low and behold no drips, hardly any coolant smell.So take the extra time to clean up the risdual coolant sorrounding the H/C. So, that added an extra 3hrs. removing and reinstalling parts to the driverside and the dash. I aslo, completly removed everything again.This allowed me tocompletely dried out the H/C and the H/C housing. I used 4 towels to soak up the coolant that was in the flr carpet. Well, I have to say I'm back in love w/ my Diamante.
Would like to note a couple of things to have. It helps to have alot of patience and be able to twist your body in positions you never thought you could be in.
I have exactly the same situation; replaced heater core 4 years ago and leaking o-rings; do you have the procedure for changing out o-rings ?
Old Apr 14, 2009 | 07:10 PM
you all wanna know what really works that DOESNT require any labor?
Go to GM.. buy a pack of their "coolant sealant" tabs. Drop 3 in your upper radiator hose.
BAM! it WILL stop the leak.
Im not a fan of band-aid type repairs, but this application is PERFECT for those tabs, and so far its worked on over 100 Diamantes without fail.
of course, fixing it correctly is a better way.. but not as quick and easy!
Old Apr 14, 2009 | 11:00 PM
Blck3G's Avatar
wow I wouldnt even reccommend it...Not worth the Damage those things do....Just unplug the coolant passage @ the firewall and Plug it up both ends.
Old Apr 15, 2009 | 09:07 AM
darcymicro's Avatar
I have already unhooked the lines to the core and joined them, so no heat. I would never put that stop leak in either, as it will clog the cooling system passages, particularly gunking up the radiator; I have seen this on another Diamante owner who used this, and when I removed the radiator cap, the gunk was clogging the top row, as it does not dissolve completely;It did not fix the leak in his and he took it to the dealer for repair, and the dealer voided his warrantee on the cooling system components after he used this; it is not a fix to the problem.
The fumes form ethylene glycol (coolant) are also toxic, and should never be breathed in.
If anyone has the procedure for replacing the o-rings I would appreciate the help.
Old Apr 18, 2009 | 04:09 PM
GTO_VR4's Avatar
I own a 02 Diamante VR-X with the common leaking heater core. My transmission went into fail safe mode and at the time, I figured the transmission was low on fluid and replaced the fluid. Well, I just got back from doing so and my transmission is still in fail safe mode. Prior to replacing the ATF, I did check to see if my HC was leaking and sure enough it was. RIGHT ON the freakin transmission computer! although the TCU was sealed with a dual layered plastic bag, i really dont see how this fluid actually made contact with the TCU itself.
As for now, I put in a stop leak fluid in the radiator system for now (i needed to flush the radiator also) and my TCU stays dry. for now.
Old Apr 20, 2009 | 05:38 PM
they "do" no damage whatsoever.
they're merely crushed wallnuts.
and bypassing the heater core mat work fine in puerto rico, but the rest of us actually need heat.
Old Apr 20, 2009 | 05:40 PM
first, im talking about the GM coolant tablets. They come STOCK in most GM cooling systems.
And im not talking about using a pound of them. Im talking about 2 or 3 tabs. They will NOT clog cooling passages if used correctly.
Old Aug 31, 2010 | 06:17 PM
iggy's Avatar
I know I'm bringing up an old thread, but does anyone have a procedure to follow regarding the o rings on the heater core. This seems to be a major problem that haunts the Diamantes, yet I'm having trouble finding a "How to..." DIY. That just doesn't seem right.
