1st issue with my 07 XLS - Delayed takeoff
Old Oct 15, 2009 | 07:41 AM
beerbaron's Avatar
the fluid is only 30000km old. when I changed it I didn't do a flush, just a drain and fill. If I remember correctly I put 8 litres back in. Maybe I'll check that fluid again to make sure the level is topped up.
Old Oct 15, 2009 | 09:08 AM
tcp's Avatar
tcp
Default How much came out?
A drain and fill is sufficient for most modern transmissions. did you measure the quantity that came out? It's very important to keep it at the correct level, neither too high nor too low. 8 liters seems like a lot to refill. My sienna has a 4 liter drain/fill on a 16 liter total system. The 2007+ outlander has a similar amount. 8 seems very high as most of the fluid remains in the torque converter and lines. you really just change what is in the pan and that is not very much.
Old Oct 15, 2009 | 09:22 AM
beerbaron's Avatar
Yeah I jacked up one side of the car extra high and managed to get quite a bit more fluid out through the drain hole.
Also, this is a 2004 I'm talking about.
Old Oct 15, 2009 | 09:38 AM
ccernst's Avatar
and when you refilled, you set it back down level?
Old Oct 15, 2009 | 09:48 AM
beerbaron's Avatar
hehe. Yeah filled it level. I've looked at the dipstick a little while ago and if I remember, with the engine running it was somewhere between the two indicators. Should I get some more fluid and get it right to maximum line?
c8gorrilaz
1st Generation
Jun 11, 2014 12:23 AM
Charles Shaheen
Sep 27, 2013 09:47 AM
freakwhensee
Aug 26, 2009 05:03 PM
radycles
Sep 13, 2008 11:07 AM
jmaxwell007
Jul 12, 2006 03:41 PM
