HELP, white smoke
Old Oct 7, 2009 | 07:18 AM
flat4's Avatar
Hi dsm1990gsx, what is hydrocarbon test? can i do hydrocarbon test my self?, do i need any special tools?
thanks
Old Oct 7, 2009 | 09:08 AM
He's right, it will show you what you want to know, but an easier way would be to just do a compression test. You can get a compression tester for a $20 at autozone.
Old Oct 7, 2009 | 04:38 PM
thanks
A hydrocarbon test is to check for combustion gases in the cooling sysyem. A local shop should be able to do the test for you.
Old Oct 14, 2010 | 08:31 PM
mtc137's Avatar
Originally Posted by TheEngineer
he just said that he has none of the symptoms of a blown headgasket
I'm failing to see where he stated that...
Old Oct 19, 2010 | 05:38 PM
kenshi's Avatar
Is it white smoke or steam? Steam will dissipate more quickly and you can feel the moisture when you put your hand behind the exhaust pipe. White smoke is burning oil. I'm having a similar problem where mine intermittently leaves white smoke when taking off and I'm fairly sure it's bad valve seals as has happened on my sportbike before. OHC engines seem to be more prone to it than OHV engines. I'd expect it to smoke all the time if it had bad rings. Nevertheless, check your oil as I find myself having to add some frequently.
Thelonewolf1220
Sep 12, 2013 06:41 PM
mbonet01
Jun 30, 2009 06:28 AM
lefecious
Jul 8, 2008 06:21 PM
BrunoBoy650
May 31, 2006 07:39 PM
EclipseSlimRS
May 16, 2004 07:10 PM
