DRL to replace Fog kit?
Old Nov 25, 2008 | 10:40 PM
  #21
tdford's Avatar
Default RE: DRL to replace Fog kit?
thanks jsrd, I'll check in the morning, and get a pic...
Old Nov 29, 2008 | 03:03 PM
  #22
tdford's Avatar
Here is fusebox for oem HID with fogs as DRL...
[IMG]local://upfiles/14180/DF426982318F4218834CA255689E3E80.jpg[/IMG]
Old Dec 3, 2008 | 08:07 AM
  #23
mitsupartsman.com's Avatar
well tdford, since the fuse and wires are still in place for the foglamps. If you were to reinstall the switch and relay,then reset the ETACS it should work.
The next question would be do you want really bright DRLs or really dim FOGs?
Old Dec 3, 2008 | 02:56 PM
  #24
tdford's Avatar
So what I need is to get the switch which would replace the left stalk, then put the new relay in the fuse box? And to make it work have the dealer reset the ETACS? That doesnt sound to bad. You think you could get me the parts, and let me know how much?
So is there a different bulb/setup for the fogs if being used as DRL's? Whats the difference? My fogs (drl's) are not that dim, as in I wouldnt be to upset leaving them the same brightness.
Old Dec 3, 2008 | 05:20 PM
  #25
the foglamp uses a halogen bulb and the DRL uses a bulb that resembles a marker bulb (27w versus 55w)
Old Dec 4, 2008 | 01:41 PM
  #26
tdford's Avatar
Could you just swap the bulbs then or is it a different connector?
I know you are the testing all thistoday, so hopefully you will find out what the overall verdict is. Thanks again!
Old Dec 5, 2008 | 10:36 AM
  #27
mightyOUTTIE's Avatar
so you guys are testing if its posibble for drls to be on the same as HIDS?
Old Dec 5, 2008 | 05:11 PM
  #28
SUCCESS! [sm=yeahsmile.gif]
i installed the switch and relay, programmed the etacs and it works like a charm.
DRLs with headlamps off FOGs switch on with HIDs.
part numbers needed;
8614A064 switch mitsupartsman nice price $79.09
mr588567 relay$22.35
or install foglamp kit number MZ380376EX $239.96
with halogen bulbs.
Old Dec 5, 2008 | 05:47 PM
  #29
tdford's Avatar
ORIGINAL: mitsupartsman.com
THANK YOU. THANK YOU. THANK YOU. THANK YOU!!!!!!
I would like to orderthe switch and relay then. How hard was the switch to install?
Does the dealer charge for programming the ETACS? What exactly do i ask them to program?
Old Dec 5, 2008 | 05:53 PM
  #30
willowpeak's Avatar
Mitsupartsman.. take some pictures of the parts. I'm curious on the switch setup...
Thanks for your help!!! Man, I want my OEM-HID and Foglights to go on the same time also. It's looks clean with both of them on.
