Lack of heat when engine is at idle
Old Nov 5, 2009 | 02:02 PM
  #31
tcp's Avatar
tcp
Default The dealer
I just buy them from the dealer. $7.90 or something like that.
Originally Posted by judgfm
=== do you buy your oil filter from the dealer, if not where do you buy it, can you give me the part number that you buy and if you know where to buy it online?
thanks.
Old Jan 10, 2010 | 06:58 PM
  #32
Mitsu28's Avatar
Eh N0C7, did you get the A/C ECU change? Just let me know, maybe I missed the others treads. I post this original tread, I have still that problem. Just wanna know if that ECU change has solve your problem.
Thank you!
Old Jan 12, 2010 | 07:55 AM
  #33
halfasleep's Avatar
I have a 2009 LS and the heat doesn't get cold but it's not the hottest I've seen in a car, what could be the problem ?
Thanx
Old Oct 18, 2010 | 06:01 PM
  #34
n0c7's Avatar
Mitsu28 - they swapped out out late last winter and it didn't get cold enough to actually see if it fixed the issue. We'll see... winter #3 coming up....
Old Apr 13, 2011 | 11:43 AM
  #35
n0c7's Avatar
Winter has come and gone and I have to say there was a noticeable difference. The idle speed has been raised when the outside temperature is low and the engine temperature is low while in drive and your foot is on the brake(eg. stop light). I'm not sure what the thresholds are but it's enough of an improvement to quit complaining at this point. The air is no longer cold but luke warm, enough to tide you over until you get moving.
Old Apr 16, 2011 | 02:53 PM
  #36
armymen's Avatar
is there any place i can see all the TSB for the outie ? so all the little small problem i can juste print the paper and show then the official thing ?
Old Feb 11, 2017 | 08:50 PM
  #37
stevet3's Avatar
Default outlander No heat
Hi. this is what I did to my outlander and I get heat at Idle no matter the low RPM. Buy on E bay audi auxiliary water pump $39 Gates hose # 19312 $7. remove air filter and housing. locate the hose that goes to heater core from thermostat housing. remove the hose, from the therm housing cut about 4" of the hose. hose is 5/8 and the pump is 3/4. spray the fitting with hair spay force hose on. hose #19312 from pump to heater core, no need to cut that hose. must put your own wires or audi / VW plug. + & - . wire it to a switch up to you where ever. Hope this helps. Pass it on especially to those in Canada. let me know. Thanks.
bkcoburn
Jun 24, 2010 11:07 AM
13adman
Apr 17, 2010 06:31 AM
n0c7
Mar 15, 2009 03:36 PM
Eclipsor
Jun 20, 2006 03:14 PM
