timing belt
Old May 3, 2004 | 08:14 PM
jwmccants's Avatar
Default timing belt
I have a 89 mirage and i broke the belt while going about 20 mph. Not knowing what the problem was at first, I tried several times to start it. After replacement the valves seem to be bad and it is running really rough. I was told that by me trying to start it was the cause of the problems. My mechanic says the head is bad but it was fine before replacement. Need some ideas as to what to do next. Thanks, Joe
Old May 4, 2004 | 09:33 AM
madmat's Avatar
Default timing belt
first of all welcome to the boards.<IMG src=smileys/smiley20.gif border="0">if you've got that many probs from a broken belt, weigh the cost of the repairs vs. replacing the car. heads can be expensive to repair.
Old May 13, 2004 | 04:35 PM
Mitsu-Tech's Avatar
Default timing belt
those valves bent the split second that belt broke ..not when trying to start it ...</P>
are you sure he put the belt on correct one tooth of it runs like crap.....</P>
I have seen it many times bought a few cars cheap that way too check the belt job ...bring the car home have someone else look at it .....</P>
if thats the case a HEAD IS NOT THAT BAD 89's hold up pretty good but if you can't get the whole job done for under 700 forget about it </P>
Hard lesson to learn evry 60k change the belt OR 5 years time wears things just as bad as use</P>
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
8000RPMS
Aug 30, 2007 05:49 AM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
