guages
Old May 7, 2004 | 05:02 PM
spyder-man's Avatar
Default guages
ok i installed some EL guage faces on my 99 spyder now the gas guage only has half the range and the temp guage does not function at all im thinking that the just need to be reclaibrated being electronic guages i installed them with the entire guage pod removed so they were unpowered. im just stuck.
Old May 13, 2004 | 04:22 PM
Mitsu-Tech's Avatar
Default guages
Are you for real ?? there is no calibrating the guages ..did you pull the needles off and put them back exactly were they were when the car was running for 10 minutes ....? both before and after installation
Old May 13, 2004 | 05:40 PM
spyder-man's Avatar
Default guages
no i didn't pull them off at all. The instructions that came sucked. at the time i knew nothing of electronic guages. (now i know just enugh to be dangerous) what i did and yes i know i totaly wrong was moved the needles to slide the faces on then moved them back. form what i can figure i didn't damage the fuel (could be worng though) it still functions only part of the range though. the temp guages does not at all it reads cold all the time. im tempted to run the car till it heats up then move the temp guage back to what was i normal op temp. </P>
for all the flames im going to get </P>
I know i shouldnt have done this without doing the research first. Im a dumbass and am probably going to pay for it when i need to get new guages.</P>
Old May 13, 2004 | 07:13 PM
Mitsu-Tech's Avatar
Default guages
well fill your tank .....run it at operating temp ....and so on </P>
If it still gives you trouble what you will need to do is this</P>
bow your head in shame and go to a dealer let them hook up the MUTT II it will give them the correct readings and set the needles where they need to be ..it may cost you 1 or 2 hours in labor</P>
Old May 17, 2004 | 11:20 PM
SpyderGS's Avatar
Default guages
Mitsu-Tech, onthe rare occasions that you give advice, you are probably one of the best guys here. Good advice.
Old May 17, 2004 | 11:48 PM
crash's Avatar
Default guages
</P>
that he is he knows his stuff thats for sure</P>
Old May 17, 2004 | 11:52 PM
Mitsu-Tech's Avatar
Default guages
Thanks You Know in this profession you don't hear that too much ..I just try to tell it like it is....<IMG src=smileys/smiley2.gif border="0">
Akubacki
Aug 14, 2011 03:23 PM
ichbindasgehirn
Nov 12, 2010 10:41 AM
itsme71190
Jul 16, 2008 12:50 PM
Sanguinius
Feb 22, 2006 11:19 PM
DNA2112
May 10, 2005 10:47 AM
