What is stock fuel pressure on a 1g talon?
Old Jun 21, 2006 | 04:23 PM
Default What is stock fuel pressure on a 1g talon?
so... what exactly is the stock fuel pressure?
Old Jun 22, 2006 | 12:07 PM
Default RE: What is stock fuel pressure on a 1g talon?
well it depends on wether its at idle or at 0 psi or at full boost. Here are the #'s
Idle = 26 psi
Zero Boost = 36 psi
Full boost (assume around 12 psi) = 48 psi
*for every psi of boost you add 1 psi of fuel pressure.
Old Jun 22, 2006 | 12:28 PM
Thank you. My friend wants to know what to set his fuel pressure regulator at with a Walbro high pressure 255lph pump
Old Jun 22, 2006 | 12:53 PM
well the FPR is mostly for idle and low boost so i would say you want to set it to 26 psi
paintballproam
Dec 3, 2006 12:32 PM
98_GstEclipse
Aug 28, 2006 01:46 PM
wicked_outlander
Feb 19, 2006 10:55 PM
player69x
Jan 25, 2006 01:20 PM
Frost
Mar 6, 2005 04:28 PM
