White smoke from 92 dohc turbo
Old Jun 27, 2003 | 04:46 AM
car doctor's Avatar
Default White smoke from 92 dohc turbo
Sup guys...i have a question about my eclipse. I just got it this monday and i already have problems with it. Its not that it dosent star or that it runs funny but theres oil spots on the floor when i park it. I knew about this when i bought it but i just found out that the car throws white smoke like crazy. I took it to a mechanic but i wont say exactly whats he said so i can get an unbiased opinion here. i want to know of any possible problems...</P>
Also, the car seems to almost give when its parked and on. As soon as i press the gas, it goes away</P>
I want to get opinions first before posting what he said</P>
Old Jul 2, 2003 | 01:05 AM
WHiTE GSX's Avatar
blown head gasket, or Turbo seal....thats my opinion without looking at it..</P>
next time you start your car, take the radiator cap off and look for bubbles.. if you see bubbles you know air is getting into the line.. meaning, 1 cracked head, 2 cracked block, or 3 head gasket...</P>
if it's the turbo seal, take your intake pipe off and check the shaft play.. if it's loose it's probably the turbo seal.. what di the mechanic say?</P>
Old Jul 2, 2003 | 05:26 AM
car doctor's Avatar
thx gsx. im getting a computer diagnostic this thursday to see what it is</P>
Old Jul 2, 2003 | 12:40 PM
WHiTE GSX's Avatar
no problem, let us know what you find out</P>
</P>
Old Dec 6, 2003 | 04:21 PM
EJ20GBD's Avatar
white smoke, burning oil.. = bad seals, oil spots = oil leak hence.... burning oil hence...... white smoke <IMG src=smileys/smiley4.gif border="0">good luck</P>
</P>
Old Dec 13, 2003 | 04:19 PM
Jessa's Avatar
It was the white smoke from the tail-pipe of my '92 Eclipse that led a mechanic to believe it was a problem with the oxygen sensor. I really hope it's nothing more serious than that... guess I'll try the radiator cap diagnostic.
My car loses power, and the 'check engine' light comes on... but only occasionally. Seems to do okay (but doesn't have the power it once did) when I put in premium grade fuel. I read another thread here, and am replacing the spark plugs, to see if that'll help.
So, I take it that the '92 Eclips is basically a P.O.S.? Or is it still, basically, a reliable car?
Also, under the hood it has DOHC 2000... it is automatic and has overdrive and normal/power transmission. But as for the specific model and whether or not it's turbo, I have no idea. It has been repainted, and there is no indication of engine type, or anything else... but when I go to parts stores, it has all these different selections. How would I figure out what mine is? Just curious. Yes, I'm an automotive moron. I can change fluids, spark-plugs, tires, and do my own brakes... but other than that, I'm your typical female. <img border="0" src=smileys/smiley6.gif border="0">
Old Aug 9, 2015 | 01:04 AM
pdparker's Avatar
I assume that the DOHC 2000 is the label on the engine? This would be a 2.0L engine. If you look on your back bumper, it may have a model designation there; GS, GST, GSX. If it does not have one of these three, then probably not turbo. The other thing they will want to know at the parts store is if you have an all wheel drive car (AWD). You can check this by looking under the car and see if there is an axle going to each of the rear wheels just like those that are going to the front wheels.
Old Aug 9, 2015 | 04:52 PM
Guyfromhe's Avatar
You realize this thread is 12 years old and that car has probably been to the crusher, right?
BrunoBoy650
May 31, 2006 07:39 PM
t4_gsx
Mar 3, 2006 07:29 AM
kingman4309
Feb 22, 2005 03:03 AM
tribalimage
Jun 6, 2004 06:11 PM
EclipseSlimRS
May 16, 2004 07:10 PM
