Questions about Stereo replacement
Old May 31, 2004 | 04:11 AM
JazAddict's Avatar
Default Questions about Stereo replacement
Hi,
Newbie
2003 basic AWD Outlander.
I'm gonna put a Kenwood 925 deck in. I'm thinking about mounting the amps in the pastic tray over the spare. I figure I can get a wiring harness for where the deck is attached cheap. I have a few questions:
Is my amp location plan any good? Any other suggestions?
Are the 2 screws under the lowest section of the dash the beginning of the puzzle to get the radio out?
Its a 4 speaker AM/FM/CD...is there an amp anywhere (that I'll need to bypass) or are the speakers powered from the deck?
Thanks,
Bob
Old Jun 2, 2004 | 01:34 PM
Audioquest's Avatar
Default RE: Questions about Stereo replacement
Here's how I like to dissasemble the dash:
1. I like to pull out the panel where the power outlet is located first. Put the gear shifter in drive for extra space.
2. Open the power outlet cap and stick your thumb in there. Pull on the entire lower panel. It should pop out pretty easily. You can set it aside.
3. Pull off all 3 heater control *****. The pull straight out.
4. There are 2 screws behind 2 of the *****. Remove them. Set them aside.
5. Now you are going to pull out the centre dash trim piece. It is attached with several plastic clips. I usually start from the bottom and pop them out slowly.
6. The radio is now accessible. There are 4 screws holding the radio mounting brackets to the dash. Remove all 4 screws and pull the radio out.
Mitsubishi radios are grounded through the antenna. Because of this, you will have to run a ground wire from the chassis to the aftermarket radio's black wire.
Old Jun 21, 2004 | 03:55 AM
JazAddict's Avatar
Thanks,
Worked as you directed easy as could be.
Regards,
Bob
Old Jun 21, 2004 | 05:20 AM
davids2004's Avatar
I noticed that the mitsubishi radios were grounded with the antenna. But once I plugged the antenna in I did have to ground it at all and it worked just like the stock radio did with the antenna as the ground.
Old Jul 12, 2004 | 10:17 AM
urbagurba's Avatar
put it in the back- under the storage lid!!
Old Nov 23, 2021 | 03:05 AM
Kickflip's Avatar
Default The harness was removed
I have a new pioneer head unit, amp and sub to install. I got the harness all hooked up on the pioneer side but car is just a bunch of wires. I was hoping someone could provide me with a simple colour diagram to connect the pioneer colours to.
The unit is MVH-S215BT
into a
2007 Mitsubishi Outlander
Thanx!!!!
jrb1and2
Jun 14, 2021 11:14 AM
mnewland00
Dec 23, 2010 05:31 PM
Addikted2wips
Nov 23, 2007 07:05 PM
Addikted2wips
Sep 7, 2007 04:13 PM
CO 3000GT
Jun 11, 2006 02:36 PM
