Installing a Commandflo Fuel Pressure Modifer
Old Aug 26, 2006 | 02:04 PM
98_GstEclipse's Avatar
Default Installing a Commandflo Fuel Pressure Modifer
I just baught a B and M CommandFlo Fuel Pressure Modifer for my 98 Gst Eclipse. Im not to sure on how to install it and to adjust it. Can anyone out there give me some tips or help me out
Old Aug 28, 2006 | 10:26 AM
Default RE: Installing a Commandflo Fuel Pressure Modifer
why are you putting on an aftermarket fuel pressure regulator? Its not something that is a quick job. Did it come with all the braded hoses needed? I would check out vfaq.com they had a good article on FPR's
Old Aug 28, 2006 | 12:57 PM
Its the B&M Fuel Pressure Modifier. It didnt come with the steel braidied hose. Its basically just to swap out the stock one with one you can modify the fuel pressure. Its not the whole thing.
Old Aug 28, 2006 | 01:46 PM
oh ok. Well i think the stock one is on the end of the fuel rail. Not sure how that one works though as far as adjusting it. And it didnt come with a guage correct? So youll need to install that as well to use it correctly.
PooT_Nation
Mar 17, 2011 01:07 AM
3000gt16
Apr 8, 2010 12:58 AM
kakarot42
May 2, 2008 07:38 AM
Quick93gsx
Sep 16, 2007 07:01 PM
Quick93gsx
1st Generation
