'95 radio replacement, help dash lights don't work
Old Sep 14, 2006 | 06:34 PM
Electech1's Avatar
Default '95 radio replacement, help dash lights don't work
The radio quit working in my '95. I want to replace it with a cheapie for now. I bought a used radio off of ebay from a mitsubishi but it did not have all the connections the old radio has.
There seems to be a connection to the interior lights through the radio. There is a fuse and connector that don't match any normal radio stuff.
When disconnected the interior lights do not come on with the headlights.
I have rigged a fix but now the interior lights are on whenever the car is started. Not a big deal but it bugs me.
I put in a cheap radio for now.
Anyone know about this? Am I crazy or just missing some info?
Old Sep 18, 2006 | 09:02 PM
Electech1's Avatar
Default RE: '95 radio replacement, help interior lights don't work
I guess i should have said dash lights, not interior lights.
The dome light works fine.
Anyone know anything about this radio that has a fuse and an extra connector on the back?
Old Sep 20, 2006 | 03:48 AM
Temet Nosce's Avatar
don't know man, shoulda jus gon to circuit city, they would have put the radio in the right way and not screwed anythin up in the car.
Old Sep 20, 2006 | 02:47 PM
Electech1's Avatar
They would not replace it, they did not have a harness that would fit it. That was a couple of years ago.
Old Sep 20, 2006 | 02:51 PM
Electech1's Avatar
If you don't have anything positive to add to my question can you just stay out of it man? Answering questions with stupid comments doesn't help anyone.
This radio is different from any other radio I have ever seen. I have installed many radios with out a problem. But this is different than the average radio.
It has another connector for dash lights going to it. It is not a normal radio.
Old Sep 20, 2006 | 03:41 PM
jeez, calm down, don't get so emotional and flip out like that, I'm jus ****in witcha. Damn. Good luck solvin the problem, take it to a dealer, maybe they can help.
Old Sep 22, 2006 | 10:56 AM
ORIGINAL: Electech1
its a mutant
thats weird that the radio would have anything to do with the interior lights
Old Sep 22, 2006 | 04:05 PM
99madewell's Avatar
Default RE: '95 radio replacement, help dash lights don't work
only reason a factory radio would connected with the dash lights is for the dimmer switch ..........what did this radio come out of exactly ?
Old Oct 20, 2006 | 04:20 AM
BioH4z4rd's Avatar
Im having the same issues with my '93 mirage... I had a new deck for a good couple months, and then it stopped working. when I removed it, the dash lights wouldnt work.
I found that the green wire with white stripe and the black wire with yellow stripe ARE in fact connected to the dimmer, and when I connect it to some sort of power from the stereo, (presumably the swtiched positive, which Im assuming is blue) the dash lights come on, but when a go to actually switch the lights on, the dash lights go away. I also noticed that my drive lights (park, drive, neutral, etc) dont work except for reverse, but that may be a seperate problem entirely, and if so, Im not even going to address it.
Im thinking if we bounce ideas back and forth between each other, and Im hoping we have the same wiring color codes, we can help each other find a solution. I know I probably should have gone to a pro, but whats done is done, I cant go back, and whats more, I dont wanna pay someone for something I can figure out and do myself, you know?
justyn01
13
Jul 10, 2011 05:34 PM
Monte98
Dec 8, 2010 01:46 AM
Electech1
Sep 14, 2006 06:41 PM
MJANGEL28
Jan 24, 2006 11:30 PM
MJANGEL28
Jan 24, 2006 04:36 PM
