Reverse Lights Don't Work
Old Jan 23, 2006 | 02:32 AM
MJANGEL28's Avatar
Default Reverse Lights Don't Work
Hey peeps, well my boyfriend has a 5-speed 99 eclipse and for some reason his reverse lights doesn't come on when put to reverse. It only works once in a while, but other than that, it doesn't come on at all. The bulbs and fuse is okay, so we really don't know what the problem is. Any ideas?
Old Jan 24, 2006 | 01:49 PM
NESpeed's Avatar
Default RE: Reverse Lights Don't Work
Check the reverse switch plug on the tranny, check for broken wires. I cant remember exactly where the plug is on a 2G. Just pull the battery tray and UIP and look around the tranny there will be two plugs. One is the speedo sensor and the other is the revese. If there plug seems ok it could be internal switching in the tranny
Old Jan 24, 2006 | 04:45 PM
get435's Avatar
also try checking the bulbs sometimes corrosion will get on the blub and can cut the power to the buld and it will speraticly come on simple cleaning will fix this happened to me.[:@]
Old Jan 24, 2006 | 08:24 PM
player69x's Avatar
if it has a relay switch you might have to replace it and have it rewired.
Old Jan 24, 2006 | 11:30 PM
MJANGEL28's Avatar
Hey thanks a lot guys, I'll have him check it out and I'll get back and let you all know what's up.
evrchanging-ecl
Jan 16, 2014 01:36 AM
justyn01
13
Jul 10, 2011 05:34 PM
Electech1
Oct 20, 2006 04:20 AM
Electech1
Sep 14, 2006 06:41 PM
MJANGEL28
Jan 24, 2006 04:36 PM
