strut ? camber issue
Old Oct 3, 2006 | 10:45 PM
bud660r's Avatar
Default strut ? camber issue
ok my camber is about 4 degrese off "top of tire is out more than the bottom" would this be a sign of a bent strut?
also what is a good strut to get for a resonable price preff under 90$ ea
Old Oct 4, 2006 | 09:45 AM
Default RE: strut ? camber issue
do you have lowering springs, aftermarket coilovers?
Old Oct 4, 2006 | 09:16 PM
bud660r's Avatar
no!
Old Oct 5, 2006 | 11:58 AM
well if the strut is bad then you would have alot of banging. This seems like some kinda other suspensoin issue, like a joint or something
Old Oct 5, 2006 | 10:47 PM
bud660r's Avatar
well i took it appart today and nothing is bent"or looks bent" i did replace the tie-rod on the passenger side "thats the side i am having all the trouble" when i brought it in to get it all lined up the said they couldnt help me, so i went to another shop and they said that it might be a strut , so pretty much i am lost and am replacing stuff till it goes away. so any help on this one is awsome
Old Oct 6, 2006 | 07:03 PM
98eclpsrider's Avatar
the only other thing that i thought of is that the frame might be bent a little. that that just happens by bending it from on side to that other, nothing that i heard of it messing up the camber.
Old Oct 6, 2006 | 09:30 PM
bud660r's Avatar
well i went to replace the upper control arm, and i noticed that one of the mounting bolts was pushed through a little, so i put in a new upper control arm and put in a washer between the car and the controll arm , it semed to make it a little better so i am going to take it up and see if the can alighn it now.
thanks for the tips!
Old Oct 8, 2006 | 04:00 PM
bud660r's Avatar
well i was talkin to some guys down at our local spot's, i didnt know that the eclips has non adj camber so they told me it's most likley a bad spring. how does this sound to you guys
FieroSS
Oct 5, 2010 12:12 AM
OscarTheGrouch
Jun 18, 2004 06:10 AM
OscarTheGrouch
Jun 18, 2004 05:50 AM
OscarTheGrouch
Jun 18, 2004 05:42 AM
ecp_drv
May 4, 2004 05:00 PM
