Flasher 4 97 Eclipse gt location
Old Jan 28, 2007 | 05:13 PM
turbo951's Avatar
Default Flasher 4 97 Eclipse gt location
Hello I hope I can get a little help .I cant seem to locate the turn signal flasher unit on this 97 eclipse gt.I was told to the right of the sterring wheel. But where I cant see it if anyone can please help me ,I thank you . The reason is the blinkers have just quit.The fuse seems to be fine and still no signals.The emergency flashers still work but I was told therey both have there own side of the flasher .Now any help would be fine .or a pic also Thanks again.
Old Feb 8, 2007 | 02:27 PM
TheAdvocate's Avatar
Default RE: Flasher 4 97 Eclipse gt location
First off, a 97 is either the GS or GST, which shouldnt really matter if its turboed or not.. Flashers are usually in the fusebox on older cars, but yours Ibelieveshould be mounted behind your vents in the middle.. If you pop those out you should see itmounted on theright side..
supermanu_l
May 9, 2014 12:13 PM
CMS062407
Dec 1, 2012 12:34 AM
kylevinny22
Mar 4, 2010 09:48 PM
Azazel
Apr 23, 2008 07:53 AM
galant4eva
Aug 27, 2005 09:49 PM
