mirage won't start
Old Jan 31, 2007 | 11:47 PM
kaw's Avatar
kaw
Default mirage won't start
I have a 95 mirage that won't start. I went to warm up the car one morning and when I came back outside it was no longer running. When I tried to start it, it ran for maybe five seconds then died. Then it wouldn't start at all. When I turn the key the engine cranks but it just will not start. I have spark. I have fuel. My timing is OK. I did once experience a strong fuel smell, so I replaced the fuel pressure regulator. Still nothing. I am completely baffled. Does anyone have any ideas as to what the problem could be? This is my only mode of transportation and I really need to get it running. Any thoughts or ideas would be greatly appreciated. Thanks
Old Jan 31, 2007 | 11:48 PM
Default RE: mirage won't start
Alternator
Old Jan 31, 2007 | 11:49 PM
What? How the hell did you come to that conclusion?
Old Feb 1, 2007 | 12:18 AM
kaw's Avatar
kaw
alternator is fine
Old Feb 1, 2007 | 12:21 AM
Are you POSITIVE you have spark?
The smellof gas tells me that no fuel is being ignited.
Old Feb 1, 2007 | 12:27 AM
kaw's Avatar
kaw
yes i have spark
Old Feb 1, 2007 | 12:30 AM
That makes no sence
Old Feb 1, 2007 | 12:39 AM
kaw's Avatar
kaw
my friend checked for spark twice and I had it both times. He pulled out the number one plug and it had a lot of gas on it. So he thought the fuel pressure regulator wasn't working and too much fuel was being dumped. But that's been replaced and it's still not starting, but there's not an overwhelming fuel smell anymore
Old Feb 1, 2007 | 12:08 PM
i came to that conclusion first because he said it started and then shut off. Too me the first thing that came to mind was alternator
Do you have any check engine lights, or a way to get codes. Maybe its the crank angle sensor
mysticrythms
Mar 19, 2014 08:17 PM
Analyzer52
Dec 6, 2013 04:58 PM
Phenom
Mar 3, 2011 07:53 AM
brian.tyalor
Mar 18, 2007 04:10 AM
90Mirage
Feb 10, 2005 02:43 AM
