Horn sounds when very cold outside
Old Feb 8, 2007 | 12:17 PM
lmohaxx's Avatar
Default Horn sounds when very cold outside
Hi guys.. i have a 2001 Mirage and when it's very cold outside and i go to start the car the horns just blows for a while. Anyone know what the fix is?
Thanks,
Chris
Old Feb 9, 2007 | 12:14 PM
Lil Evo's Avatar
Default RE: Horn sounds when very cold outside
hahaha, i think your car is posessed, try a priest. electrical problem somewhere, could be a million things. the only way to find out is to look at every single wire, make sure it's not stripped or grounded improperly.
Old Feb 9, 2007 | 10:07 PM
I think it either has something to do with the current arcing or the contacts being effected by the weather.
Old Feb 24, 2007 | 03:22 PM
soundcolor's Avatar
eh, just disconnect the damn thing...
No really the problem is that your horn is old and needs to be replaced... Something has probly dented it, and so when its cold, the unit shrinks, and contacts the ground... replace it, or just unhook it... your choice.
Old Mar 24, 2007 | 06:39 PM
bugeater5's Avatar
The last suggestion seems plausible, but I have an '01 Montero Sport with the same problem. Once it gets cold the horn goes off and I have to pull the fuse. After some research, lo and behold, a whole bunch of Mitsu owners have had the same problem. So I think it may be more than just a bad horn and hopefully someone will come up something. I'll start witha new horn, but I'm interested in the cause beyond just treating the symptom.
Old Jun 27, 2012 | 05:59 AM
Daryl K Gibson's Avatar
i think it is a recall problem and mishibishi should have done something my 2002 horn goes off at 3 to 6 am and i have to take the fuse out and the year is 2012 now and the same problem keeps comming back and a car cant pass inspection with a horn problem so mishibishi is getting over for not recalling the vehical to fix the problem
Old Mar 1, 2013 | 12:54 PM
jessica696912's Avatar
If you buy a louder car horn it will work better in very cold weather.
raskalla
Dec 17, 2013 01:27 AM
armymen
Apr 20, 2012 11:39 AM
rockford04
Feb 2, 2009 10:36 PM
athineltlc
Sep 5, 2008 09:51 AM
dykesjs
Oct 3, 2006 12:30 PM
